RE: Is there really a difference
Why would it be confusing . The first planes I flew only had elevator and rudder. So the left stick controlled the roll and the right the pitch. But I was thinking of a V-Tailed sail plane which doesn't have a rudder but only elevators. So after reading what you typed if I purchased this type of plane, and used V-tail mixing I would have to use two sticks to fly . But what I am thinking is if I use the aileron mix instead I will be able to fly the plane with only the right stick and use the left for throttle.
Thanks for the info I will try it some time.
