RE: Fun Factor ST/MT Shaft replacements
OK guys don't do like I did. I forgot to use thread lock on the set screw of the swing shaft. Of course the screw backed out and the pin came out then chewed my hub up pretty good. The ending result being the dog bone fell out some where in a big parking lot. No clue as to where it is?? Well guess it's time to order the stainless steel cvd's.
alvinl, I would be careful with the MIP shafts. From what I can tell the ball end on those are too big to fit in the CEN diff cup. I have tried another set of MIP's and that was the case. Unless you can figure out a way to use the diff cups too I don't think they will work. HTH.
