RE: THANKS DEVIN AND BRYAN
Ditto....glad I could be of assistance.
Here's a tip. If you've never flown indoors....PRACTICE outdoors using Rudder to turn!!! Its really difficult for newbies to indoor flying to fly turns with the ailerons and elevator. The plane will fall out of the sky really quick indoors. Get some good practice turning the plane in flat turns with the rudder.
When you get indoors, it will seem REALLY small. Just keep your airspeed low, and coast around getting use to your new environment, use your rudder to turn, and you'll get used to it quick. When I first started flying indoors, I thought there was not enough space to do different maneuvers....now, I have TONS of space. I can do an entire routine on one have of a basketball court. As you get used to flying indoors, it gets easier and easier.
