RCU Forums - View Single Post - converting a trycycle gear to a taildragger
Old 02-03-2006 | 06:22 AM
Newc
Default RE: converting a trycycle gear to a taildragger
I converted a trainer to a taildragger some years ago and simply installed an aluminum gear so that the wheel's axle was just a small bit ahead of the leading edge of the wing and installed a tailwheel. Obviously you need to reinforce the area where the gear will be attached with plywood and triangle stock between the plywood and the fuse sides and/or formers.
Make sure that the wheels are well aligned by making sure that both wheels are the same distance from the rudder and nose.
