RE: Does the RealFlight controller work for AFP/AFP Deluxe? Yes it does!
I was going to do this about a week ago, but a virus shutdown my Firewall. Well this is how, I currently have my RealFlight transmitter setup. I did not need to go into the control panel to setup the controller. My system had a 3 axis max and not a 4 axis max, so this was useless. If you do not understand this, it is on page 7 of the english part (last 1/3 of the manual.) Make sure the RealFlight controller is plugged into a USB port and the AFPD interface cable plugged into a USB port. (Start AFPD) Then go to calibration after the neutral positions is done. The full extent of travel part is not easy (remember page 13 on this part for min. to max. positions), but I have learned to use one hand before clicking the mouse with the other hand. I have not had any luck with dual rates or idle up modes. I use the dual rate switch for smoke, since it works different from the rest. It takes 3 movements like up(off), down(on), up(on) to turn on smoke and to turn smoke back on down(off), up(on), down(on). Function 21 on picture is for the idle up swtich to control wings from vertical to horizontal function on the Corsair download. I hope this posting can help!
edited dual rate switch to correct movements
