RE: Don Smith P51 mustang
Hope you have good building skills! The plans were fine. Who cut your kit for you??? I had mucho trouble with flaps being out of line and parts being wrong sizes for spars and such. Not real impressed with kit cutter. The retracts are a ton of money!!! Also, the 80 will probably NOT be enough unless you go with the new Super 80 (9.6 hp). Then you will have a weight issue at the nose. I would go as big and heavy as possible for the engine...Check out Yardy w/ the inline.
Good luck...I have kinda abandoned this one for a while...just doing some flying.
Rb
