Post 3 does not say that he lowered the tank, only post 7
ORIGINAL: Rcpilet
Cyclic Hardover:
Well you can buy plugs, pumps, change nitro and waste quite a bit of money and your problem will not be solved until you lower the tank. Can you cut out the mounting bulkhead and rest it on the bottom? I run three planes like this. I cut out that bulkhead and made a new design to hold it securely on the bottom of the fuselage in the nose. All these planes run perfectly. Other than that, can't help you.
He already lowered the tank. It worked.
Go back and read post #3 and post #7.
