RCU Forums - View Single Post - ZDZ 50 NG problem
Old 02-04-2006 | 10:14 PM
rmh's Avatar
rmh
Default RE: ZDZ 50 NG problem
the arm that came on the throttle hit a high/low stop - It is easy to remove this when adapting another arm - and the common result is that the throtle plate now will turn over in the bore . So getting the throttle plate to stop horizontally in the bore becomes a setup of the servo linkage .
worse yet - often, the plate is rotating the wrong direction - and the engine runs badly -hard starting - no midrange etc..
