ZDZ 50 NG problem
Old 02-04-2006 | 04:46 PM
dale691's Avatar
Default ZDZ 50 NG problem
Hi all i have just put a new zdz 50 in my aircraft and i don't know if it's a tuning problem but the motor takes a bit to clear after the first start, then it;s fine with the transition but a funny thing happens from about 3/4 throttle to full throttle i drop revs. there is no problem with the servo geometry so i guess it is a tuning problem, any help would be appreciated
Cheers Dale
Old 02-04-2006 | 05:53 PM
Antique's Avatar
Default RE: ZDZ 50 NG problem
If there's no throttle stop the carb could go past wide open....Maybe too rich on the high speed needle...
Old 02-04-2006 | 05:54 PM
rmh's Avatar
rmh
sounds like someone removed the throttle stops --- the throttle plate is going past center position.
Old 02-04-2006 | 10:02 PM
dale691's Avatar
isn't the throttle stop on the high end part of the craby case it self?
Old 02-04-2006 | 10:14 PM
rmh's Avatar
rmh
the arm that came on the throttle hit a high/low stop - It is easy to remove this when adapting another arm - and the common result is that the throtle plate now will turn over in the bore . So getting the throttle plate to stop horizontally in the bore becomes a setup of the servo linkage .
worse yet - often, the plate is rotating the wrong direction - and the engine runs badly -hard starting - no midrange etc..
Old 02-04-2006 | 10:28 PM
dale691's Avatar
I have not changed the linkage arm but i have removed it and put it back on, i can't get a good look down the bore while the motor is in the plane. the stop that i was thinking about is the one on the otherside of the carby, the one where there is the idle stop is.
Thanks for your help
Old 02-06-2006 | 06:27 AM
dale691's Avatar
It seems that the top end was a little lean, the problem seems to be better, not sure if is the correct fix, does this sound like a symptom of a lean top end?
