RE: Saito FA- 83 help needed
That's the crankcase vent. Horizon says to put a 3 inch or shorter piece of fuel tubing on it and let it exit the cowl. On a plane with the training wheel on the nose I sometimes just fix it to that. If you need longer use a larger diameter tubing. It is also the place to inject after run oil if you think you need to.
FEB
