mvvs 49
Just want to add that I had a similar problem; runs fine on the ground but splutters in the air with a OS40. I discovered a few frustrating flights later that the back plate of the crankcase had all 4 bolts that were loose. Although why that should effect performance in the air only I couldnt figure out But I tightend the bolts and the engine is perfect since.
