RE: ZDZ-60 Problem
Hi,
Try to richen the low speed needle a bit and see if it helps. Also, I don't believe RC Showcase will warranty your engine with you running 100:1 amsoil. The last I read, they want a richer oil mix. You may want to check with RC Showcase on the recommended oil and mix for ZDZ engines.
Elson
