YS 110 Quits at idle
I purchased a YS 110 with a recient plane and it runs wonderful everywhere except low idle. Its like it is either losing its spark or drawing air from SOMEWHERE. All other setting are flawless. Its a little touchier than my other YS 120-140's like it may be drawing a slight amount of air from somewhere but is easily adjusted at top end. I run cool power 30% heli in all my 4 strokers so its not a fuel issue. Took all my nipples off and checked for any small trash or restrictions tonight and alls clear. I did change the plug as a long shot thinking it may be sucking air through there and will test again tomorrow. Been fighting this for a while now and its getting close to being sent off. I've run mant different tanks with the same results. Even had a YS guy look at it at a contest and he couldn't adjust it out either. The low needle has to be all the way screwed in for the best possible run at idle, but it still quits.
HELP,
Jamie
