Hi Jerry,
Unfortunately, the FGK series radios took a completely different module than the newer TP, or TJ series. The older ones were physically larger and the newer models will not fit into the 7FGK.
You may be able to find an FM module for this series radio at an RC Swap site.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
Futaba Service Center USA
ORIGINAL: JerryMH
I need to upgrade my transmiter from AM to FM but need to know
if i can use a FP-TP-FM module with this radio. I see modules with
FP-TP-FM , FP-TF-FM , FP-TJ-FM and FP-TQ-FM what is the difference.
The radio is a FP-T7FG/K with a AM module at 72.160MHZ
Plese Help
