RCU Forums - View Single Post - 2006 Advanced Sequence Question
Old 02-06-2006 | 04:53 PM
aviationinfo
Default 2006 Advanced Sequence Question
Hello to all, I have a Q on 2006 Advanced Sequence, #7.
If I'm reading it correctly, it's actually a Cross-box maneuver, and the pilot gets to decide whether to pull at the top either toward himself or away, depending on which way that quarter roll is done. So you're going to end up not on the same line from which you began.
So if this is the case, it seems to me like you need to be flying the rest of the sequence with this in mind---knowing you're going to be bringing the plane closer or farther away laterally in #7. So won't that mean that either the first 6 maneuvers are going to be spaced either too close or too far away, or the last three are? I can't remember---is it OK to readjust your line back in or out for the next maneuvers? I'm thinking it's probably not.
I appreciate any thoughts on the subject. I've been away from IMAC for 8 years and I'm trying hard to pick up where I left off. I've practiced some every year, just not entered any contests.
Thanks!
