ORIGINAL: tsperling
Claud,
I notice that u used what looks like a peice of fuel line on your brake linkage instead of the spring that came with it. Why did you make the change? Does the fuel line increase the pressure on the brakes and increase braking power. I have noticed that the LST2, out of the box, does not have that much braking power. Will your change solve this problem?
Tim
The LST2 has Lots of Braking power, You must Not have it Adjusted Up?
