RE: reedy quad mag
It is the speed stocker, and it beats t-maxxes running 20%nitro for about 20 seconds then the maxx slowly starts to creep up, that's the only way i'm judging the speed, but it also smokes the 19t i'm running with the same gearing. I'm telling you, if i'm running on a cleaning with good brushes it'll easily do 25-30mph. I have never cut the comm, as you can't because the endbell is locked, but it still rips after at least 50 runs. I can't really believe it either but is is insanely fast for a stock motor. If i hold the tires off the ground and gun it they balloon to like a 5 in diameter running foam inserts.
