RE: BRIO Construction by the numbers
What spinner will you be running jlachow?
Can not imagine how you would mark landing gear correctly for drilling out in that tiny space that is provided in the fuselage strange setup..
Seemed only logical to drill through the fuse, but you would think designing ideas would have solved that issue BEFORE the completion of the plane's final design...
Like the locking nuts idea, did you also strengthen the landing gear area as well???
I like the deluxe version seems solid for such little internal structure..
Don your building tips are great thanks!! Charlie
