RCU Forums - View Single Post - Synergy 90 ARF
Thread: Synergy 90 ARF
Old 05-18-2003 | 06:18 PM
  #199
kris1
Default Synergy 90 ARF
hi Guys
Just been looking at my aircraft. I see the Ailerons horn position problem. I recon that MK rudder horns part no 0812 will work. I am using Hitec 8925's and I will use the ali servo arms. With these horns I can fit them into the tri piece on the aileron with no problem and still get the required 3D deflection. I woul have prefured longer turning moment though. Looks like the geometry could be out though, if it is then I will change the plasic horn end for a longer one. The same horns look to work out well for the elevator. They will not work on the rudder though, they don't get the clearance from the elevator, at least on the closed loop set up. I will have to think about this one.
What are you guys doing about reinforcing the UC area?
Kris
