RCU Forums - View Single Post - The unofficial Home of all that is Nitro Vee...
Old 02-07-2006 | 07:24 AM
NITRO_VEEDRIVER's Avatar
NITRO_VEEDRIVER
Default RE: The unofficial Home of all that is Nitro Vee...
i have an air fan in bathroom so that wont be bad. i kinda like the dual exhaust on back . so i dont know if i will be getting a pipe for it. unless i can get a dually. one question? how does your elecs take the heat from this pipe you have? any problems?what did you use to make sure the water did not get into the boat on the side? have you tried to use the stock muffler when you got it? how did it perform with the exhaust and water valve on it...? if i do anything more to it i'll do the cooling hose out to the side and get some chrome pieces to put on the muffler ends.
