RCU Forums - View Single Post - The unofficial Home of all that is Nitro Vee...
Old 02-07-2006 | 04:45 PM
NITRO_VEEDRIVER's Avatar
NITRO_VEEDRIVER
Default RE: The unofficial Home of all that is Nitro Vee...
well now i am in a real bind, i found out that nitro fuel got under the whole floor between the bottom of boat and where engine is. so i cut out the bad parts, luckily my mounts are all fine.. ii have some thin plastic squares about 6x6 inch and maybe 1 cm in thickness. so now i am goin to make a new floor for this. gonna make sure that nitro dont get under there again. i used windex to clean the nitro off and wiped it bone dry. also had cracks that i found from where it was damaged. i then coated these cracks with crazy glue as to prevent them from opening if i hit a wave or something., when i get done making a floorpan i'll hopefully have my digi back. so i will post the boat as it is now and then also with new floor plate.as for the pipes at the back i might have a custome made set with chrome on it.duallys at that...
