RE: Smoke pump nozzle test question
Ben,
water is quite abrasive in it's untreaed form direct from the tap due to the presence of minerals etc. It will cause premature wear on the shaft seal (lip seal) in the smoke pump. Even if you use deionised water the pump would suffer due to lack of lubrication.
/Johan
