RCU Forums - View Single Post - MVVS 58 - From new
Old 02-08-2006 | 08:41 AM
domstevens
Default RE: MVVS 58 - From new
Thanks for the info -
I agree from my post - the richening has prob been about 1/2 a turn in total, certainly not 2 turns - but the positions are not changing in flight.
First to check will be the pickup - Is there much adjustment there ? as the magnet (1) and mounting screws for the sensor are fixed ?
It has certainly picked up RPM - now pulling 7000 on a 24x10 Menz
Which leads to my 2nd problem of noise - over 100db at 3 metres - which is a problem with my new airfield having noise restriction at 95db
I hope to fix with a different prop, and will be trying a 24x12 3w and 26x10 Menx next
Would you class the MVVS canister a muffler or as a pipe, as I have plenty of horses - I may have to change ..
Have you any thoughts on my predicament
Model - Composite ARF 2.3 Extra
Best regards
Dominic
ID:	404232   Click image for larger version
ID:	404233   Click image for larger version
