RCU Forums - View Single Post - Add-ons #2 question On Load Up
Old 02-09-2006 | 06:38 AM
RCShadow
Default RE: Add-ons #2 question On Load Up
Maybe this will help (??)...
During the installation process, the loading (splashscreen) disappears then nothing happens.
Applies To
RealFlight Classic
RealFlight Deluxe
RealFlight Add-Ons #1 and #2
Occasionally applies to RealFlight G2
Resolution
If the splash or loading screen appears momentarily on the screen and then disappears without continuing the setup procedure, it is necessary to access and download the installation fix. When downloading the file please make sure that the RealFlight CD-ROM is in the CD-ROM drive. Once the file has been downloaded you’re your PC, please run the installation fix. The installation procedure should proceed normally.
The "fix" can be found here...
http://www.gpsoftware.com/downloads/...llationFix.exe
I hope this helps move things along. Make sure you have the CD in the drive before clicking the link. You will need to click on the "Run" button when it appears.
CJ
