Add-ons #2 question On Load Up
CA
I can't get realflight add-ons #2 to work with my G3. I got 3,4, and 5. When i load it the program asks what language and starts but never loads!!!!!!!!!!!!!!!!!!!!!! I thought it needed more time so i Left it alone for an hour and it never loaded! Can some one tell me what the Problem Is?[
May be the "older" version disk issue or you could have bad media. In either case, check out the Knife Edge Forum or contact those guys and they can get you sorted out.
CA
What I was saying was that it would'nt even bring up the serial code screen!..................................On the add-ons[
My Feedback: (10)
PA
ok I'm sorry I must have understood it wrong. did you try doing a search on here to see if anyone else had a problem with the ad ons and how they fixed the problems ? other then that I don't know what else to sujest.
TX
Maybe this will help (??)...
During the installation process, the loading (splashscreen) disappears then nothing happens.
Applies To
RealFlight Classic
RealFlight Deluxe
RealFlight Add-Ons #1 and #2
Occasionally applies to RealFlight G2
Resolution
If the splash or loading screen appears momentarily on the screen and then disappears without continuing the setup procedure, it is necessary to access and download the installation fix. When downloading the file please make sure that the RealFlight CD-ROM is in the CD-ROM drive. Once the file has been downloaded you’re your PC, please run the installation fix. The installation procedure should proceed normally.
The "fix" can be found here...
http://www.gpsoftware.com/downloads/...llationFix.exe
I hope this helps move things along. Make sure you have the CD in the drive before clicking the link. You will need to click on the "Run" button when it appears.
CJ
Applies To
RealFlight Classic
RealFlight Deluxe
Resolution
CJ
My Feedback: (10)
PA
ORIGINAL: RCShadow
Applies To
RealFlight Classic
RealFlight Deluxe
Applies To
RealFlight Classic
RealFlight Deluxe
My Feedback: (10)
PA
man that reall sucks. Hope you fugure it out. when I installed ad on #2 all I had to do was use the serial number I posted earlier. Of course my problem was different from yours.
CA
[sm=crying.gif][sm=crying.gif][sm=crying.gif][sm=crying.gif][sm=crying.gif][sm=crying.gif][sm=crying.gif][sm=crying.gif][sm=crying.gif][sm=crying.gif][sm=crying.gif][sm=crying.gif][sm=crying.gif][sm=crying.gif][sm=crying.gif][sm=crying.gif][sm=crying.gif][sm=crying.gif][sm=crying.gif][sm=crying.gif][sm=crying.gif][sm=crying.gif][sm=crying.gif][sm=crying.gif][sm=crying.gif][sm=crying.gif][sm=crying.gif][sm=crying.gif][sm=crying.gif][sm=crying.gif][sm=crying.gif][sm=crying.gif][sm=biggrin.gif][sm=crying.gif][sm=crying.gif][sm=crying.gif][sm=crying.gif][sm=crying.gif][sm=crying.gif][sm=crying.gif][sm=crying.gif][sm=crying.gif][sm=crying.gif][sm=crying.gif][sm=crying.gif][sm=crying.gif][sm=crying.gif][sm=crying.gif][sm=crying.gif][sm=crying.gif][sm=crying.gif][sm=crying.gif][sm=crying.gif][sm=crying.gif][sm=crying.gif][sm=crying.gif][sm=crying.gif][sm=crying.gif][sm=crying.gif][sm=crying.gif][sm=crying.gif][sm=crying.gif][sm=crying.gif][sm=crying.gif][sm=crying.gif][sm=crying.gif][sm=crying.gif][sm=crying.gif][sm=crying.gif][sm=crying.gif][sm=crying.gif][sm=crying.gif][sm=crying.gif][sm=crying.gif][sm=crying.gif][sm=crying.gif][sm=crying.gif][sm=crying.gif][sm=crying.gif][sm=crying.gif]
I'm so sad!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!
