RE: Carb Question
One other thing.....
If you have a carb with the two fuel lines instead of one....
The smaller line (or the one that went to the finger pump) must be plugged with a piece of fuel line and a bolt if you are not using the little finger pump.
Without the finger pump, the carb will suck air through this line.
If you have trouble figuring which line is which, Get back on here with us.
There are at least a dozen regular guys in this forum that can tell you all the info that I have.
Enjoy,
Jim
