RCU Forums - View Single Post - shockwave 36 problems
Old 02-09-2006 | 10:14 PM
smallfish
Default RE: shockwave 36 problems
jeremyd,
Welcome ! My best suggestion is to read the shockwave thread. You will find your answer there and also get some info into other challenges with this boat. Your prob sounds alot like a pressure leak in your fuel system. Check your fuel cap,fuel lines,pressure fittings and hose on your exhaust system. Also make sure your needle valve is set around 2.5 turns open . Hope this helps
Greg
