RCU Forums - View Single Post - AMD Hawk.
Thread: AMD Hawk.
Old 02-10-2006 | 12:59 AM
  #546
scapjet
Default RE: AMD Hawk.
ORIGINAL: FOShowNoClass
..... Just by looking, I think the .91/Dynamax will fit. It will be a heavy plane, but as we've seen people have flown some heavy versions of this. I'm always big on keeping it light. A K&B 7.5 CC and a Macs pipe is supposed to put out around 7 lbs of thrust. That's what I've heard anyway. If the plane is kept at around 10 lbs, which may or may not be possible, It should go very well. I think the .91 version will weigh 2 lbs more. High wing loading, but will fly no problem in my estimation. I'm guessing a .65 or .77 would be ideal. I'm no expert.
Will
I have a A4 Skyhawk JHH, weight is 12.5 lbs with a .77/Dynamax and it flies great, so the same .77/Dynamax on a 10 lbs Hawk should be perfect.
I also have a .91/Dynamax so if possible I will built so that can use both and will see what's best.
scapjet
