RCU Forums - View Single Post - Would this really work?
Old 02-11-2006 | 10:42 PM
Vertical3-D's Avatar
Vertical3-D
My Feedback: (20)
Default RE: Would this really work?
heres mine, but its been bettered and changed a bit since this so ill post you some new pics later, its easy to build on from a tlt-1, but a stock tlt-1 even if equiped with 2.2 wheels wont be a capable machine, all the diffs need to be locked, and yeah stock they sit low, also have less than spectacular articulation in stock form, if you use t-maxx turnbuckles to link it then it streches it out, also putting a stampede trans in it and using traxxas slider shafts for the driveshafts is a good idea, crawling is all about building and modding on your rig to get what you want from it, also mine is fast for a crawler topping out at just over walking speed, about 5-8mph id say, mine is pretty in depth build though, narrowed wheels and modded tlt chassis, stuff like that, anyway here are the pics, since these i lowered it a bit, lowered the battery a bit(its between the plates now), and now has moab 2.2s on it instead of the dirtworks.
ID:	406529   Click image for larger version
ID:	406530   Click image for larger version
