RE: homemade push/pull will it work
When you pull up, doesn't the front engine lean slightly and the rear engine richen slightly ? This often is apparrent during the take-off acceleration. That combined with the (usually modified) rear muffler can lead to a tricky tuning situation.
Therefore , place the engine that is the most forgiving, in regaurds to its tuning, on the rear of the plane.
