RCU Forums - View Single Post - Duel Elavator servo setup...Need help
Old 02-12-2006 | 08:51 AM
gunfighterII's Avatar
gunfighterII
Default RE: Duel Elavator servo setup...Need help
Sounds to me like you have a travel issue with channel 6, I think it will have to be trimed with the channel 6 knob, you need to go in and match your travel volumes first and then center your #6 knob, also as said before you must have your mix activated either by computer or switch. All the dual rates and travel volumes have to be equalized, before you even start, check the expo too.
