RCU Forums - View Single Post - homemade push/pull will it work
Old 02-12-2006 | 09:29 AM
2slow2matter
Default RE: homemade push/pull will it work
Wouldn't the rear tank need to be placed differently than the front? I mean, if it's placed with the fuel lines exiting to the rear of the plane (straight to the rear engine), then that would put the clunk in the forward position. Anytime you'd go into a climb--such as takeoff--then the fuel could run to the front of the tank, and away from the clunk. How do you solve that problem?
