Originally posted by pceagon
Have anyone else had problems with excess play between the wing tube and phenolic's in both the fuselage and wing? Mine has a lot which cannot be good.
Paul
I just picked up mine, haven't looked at the wing tube fit yet. But in a previous plane, I had the same problem. I just applied 1 layer of adhesive monokote trim sheet around the tube to add thickness, so the fit is snug. You should try to see how much it takes to get to a snug fit.
I shall see how well my tube fits.
