RCU Forums - View Single Post - Multiplex Magister RTF
Old 02-13-2006 | 03:49 PM
  #174
TManiaci's Avatar
TManiaci
Default RE: Multiplex Magister RTF
Guys,
Been following your efforts, and reading elsewhere about flaps VS flapperons...
I think you'll be very dissapointed in the effects that a flapperon (artificial flap) will produce. First, it increases the tip-stall tendencies of the wing significantly, and the aileron is not large enough to be effective as a flap. Flaps apparently need to be large (30-40% of wing chord) inboard sufaces near the wing root to do the job properly without diminishing the roll control and causing too much drag.
