RCU Forums - View Single Post - World Models Fun Fly 3D 1.20
Old 04-19-2003 | 04:23 AM
  #239
GalenB
My Feedback: (18)
Default World Models Fun Fly 3D 1.20
In the process of learning to see if the GSP method of mounting the rudder servo would work I discovered the solution to the extra servo tray. Glue it to the inside of the fuselage! Problem solved...
I guess my pull-pull geometry isn't quite right. The non-pulling side goes slack about half way through the rudder's travel...
Well -- mine is almost done. I need to finish the programming and set the CG. The box of little bits in now empty!
