RCU Forums - View Single Post - World Models Fun Fly 3D 1.20
Old 06-02-2003 | 10:13 AM
  #298
pequeajim
Default World Models Fun Fly 3D 1.20
GalenB:
This is from my 9CH
Receiver Configuration
Channel Function
1 Right Aileron
2 Right Elevator
3 Throttle
4 Rudder
5 Right Flap
6 Left Aileron
7 Left Flap
8 Left Elevator
9 Battery 1
DSC Battery 2
Fun World 3D Futaba 9C Radio Programming
Function Action/Result
Press and hold the <Mode/Page> button Hold for 3 seconds
Press the <down cursor> button [Basic(ACRO)] page 2
Press the dial to select [Aux-CH Select]
Move to CH5 and turn dial CH5>NULL
Move to CH7 and turn dial CH7>Vr-E
Press <End> [Basic(ACRO)] page 2
Press the <Mode/Page> button [Advance(ACRO)] Page 2
Select Flapperon Activate Flapperon
From the Advance ACRO menu cursor to page 2 [Advance(ACRO)] Page 2
Select Ailevator Activate Ailevator
Select Air Brake Activate Air Brake
Setup Program Mix 1 Master - Aux 1, Slave - Gear
Link - Off
Position - Null
SW - C
Position - Null
Rate - L -100%, H -100%
Offset - 0%
Setup Program Mix 2 Master - Aileron, Slave - Aux 1
Link - Off
Trim - On
Position - Up
SW - C
Position - Up
Offset - 0%
Setup Program Mix 3 Master - Aileron, Slave - Gear
Link - Off
Trim - On
SW - C
Position - Up
Offset - 0%
Setup Program Mix 4 Master - Aux 1, Slave - Aux 1
Link - On
SW - C
Position - Up & Center
Offset - 0%
Setup Program Mix 5 Master - Gear, Slave - Gear
Link - Off
Switch - C
Offset - 0%
May not be the best way, but I get all of the functions, break, ailevator, coupled flaps.
Jim!
