Can't go wrong
You can't go wrong with this bird. It tracks beautifully, is VERY tough and is a great pattern type aerobatic plane. Snaps great too. Agree with reinforcing the landing gear block before it ever makes it to the field. I left the original ply in there and epoxied 3/8 ply blocks between the stringers above the stock LG plate. Tap for 1/4-20 nylon bolts and fly the snot out of it. I installed pull/pull rudder and CF pushrod elevator (single servo) just because of personal preference...all standard servos - 3003's.
With a Saito 91 running 30% nitro up front, it has all the power you would need for IMAC type maneuvers, vertical is virtually unlimited. I run an APC 13x9 on it and would think it would be great for the OS too. Great match for the plane.
