Originally posted by Ground Zero
[B what servos are you guys running in your planes? [/B]
I'm using the new Hitec HS-5475HB digitals on the elevators and ailerons. I am using an HS-645MG on the rudder, and HS-425BBs on the flaps (I may promote these to 5475HBs), and a std servo on the throttle.
I am really impressed with the power draw and speed of these Hitec digitals. I am using a 5 cell 1100mah pack and after 30 minutes of flying there seems to be a lot of juice left... I need to discharge to know just how much, but the voltage is still above 6.4 volts...
