RE: Basic Servo Question
Two differences:
1. The color of the wires.
2. The shape of the connector.
Futabas have an alignment key to prevent you from plugging the servos in backwards. Otherwise, pin spacing and order are the same. As long as you keep the connectors in the same orientation (i.e. the little clippy-things that hold the pins in are facing the same direction), it doesn't matter which you use.
