RCU Forums - View Single Post - Install the DEPS elevator system in a painted fuse
Old 02-14-2006 | 03:05 PM
  #59
ExFokkerFlyer
Default RE: Install the DEPS elevator system in a painted fuse
Chris, I guess I am surprised that I'm using DEPS again too... I did swear never again! But I guess I wanted to give the DEPS one more try. I proved with my last plane that you can screw it up royally in the installation and still be able to fix it into a proper hook up. So I was a little less stressed with the Genesis. I elected to go with the two rods joining at the servo horn. The installation is not totally complete, one of the titanium female fittings was without a hole... so that stopped my progress last night. Called Central this morning and they are sending out another one for me... But even with that it looks like this will work pretty well.
I ended up with the rods exiting about 7.25" from the horn, and it looks like it should be pretty tight. The first time we tried lining things up the exit was going to be about 11". That being unaccepable, I moved the horns in as far as I could go and was able to knock off about 4". Should work pretty well now.
