Hi Duane,
I am not sure if the pin arrangements were the same or not, but we are not allowed to give this type of information out. I really don't know on these older modules if they would just snap in place and work or not.
The TF module was never offered on 27Mhz or 75Mhz, only 72Mhz. Also this cannot be retuned by us, as we no longer carry parts for it.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
Futaba Service Center USA
ORIGINAL: oldlugs
Thanks much Krysta!
Now I know which ones to look for.
Two more questions... Is the pin arrangement the same on the FP-TF-FM as the FP-TD-AM; will it just snap in place? Also, was the FP-TF-FM offered in surface frequencies (27 & 75 mhz), or if not, can an air frequency be re-tuned to 27 or 75 mhz?
Cheers,
Duane
ORIGINAL: Krysta
Hi Duane,
No problem, I just wish I could help you out. Unfortunately, again, we don't have any of these modules for these old units.
Yours probably has an FP-TD-AM module in it, as it is the same size as the FP-TF FM module that was used in the FGK series, this one would make the switch for you, but you will have to do some searching to find one. RC Swap meets, either online or local ones, are a great place to find parts for these radios.
Sincerely,
Krysta
ORIGINAL: oldlugs
Hi Krysta, please forgive me for reviving this old thread... I've got a Futaba 3EGX radio that I like (on 75mhz), and want to convert it to FM. What module should I be looking for to do the conversion? Thanks for your help!
-Duane
