RCU Forums - View Single Post - Stalls after hitting Second Gear?
Old 02-15-2006 | 02:52 PM
chopper22980's Avatar
chopper22980
Default RE: Stalls after hitting Second Gear?
I have a volcano stx.I had the same problem with mine,so I adjusted the high speed valve.Thats the one beside your air filter.I had to richen the mixture.So try to turn it counter clock wise and see if that helps,it did with mine.Turn it a little at a time and see how it does then.Hope this helps your problem.
