RCU Forums - View Single Post - Mid-Atlantic Combat????
Old 02-15-2006 | 04:38 PM
Montague
Default RE: Mid-Atlantic Combat????
You have a hole in your engine? Is it just a loose fit between the muffler and case, or something larger? If it's just a loose fit, try using some RTV to make a gasket for the muffler. If it's something like a chip then you should be able to fill it with JB Weld. Just make sure to clean it off really well first.
