RE: Old Cat needs ESC
Gordon,
Simplest thing to do is to determine how much current your motor draws at max and get an ESC that's rated for that. That usually means doing a 'stall' test on the motor to find max amps. Then just read the ESC specs till you find one that will handle it. A little 'extra' ESC is better than not enough ESC.
- 'Doc
