Go Back  RCU Forums > RC Boats > Speed - Electric
 Old Cat needs ESC >
Old Cat needs ESC
Speed - Electric For all your electric boating needs.
Old Cat needs ESC
Old 02-11-2006 | 12:37 PM
Default Old Cat needs ESC
I have an old Cat that used 2 6 cell batteries and twin engines. The mechanical speed control switched the batteries from parallel to serial so half speed was 7.2 volts and full speed was 14.4 volts. I think it had a slow and/or reverse that ran through a resistor. I want to revive it with an ESC. Any recommendations? Maybe an eTraxx ESC?
Old 02-11-2006 | 12:54 PM
Default RE: Old Cat needs ESC
Gordon,
i have a rc hydro speed control i will sell you, it been completely remanufactured from rc hydros. here are the specs it would suit you perfect ! $75 + shipping.
let me know, thanks , Dave
- V60-612/BEC Features -
# Watercooled & Waterproof
# 6-12 cells
# 1Amp BEC good for 1-2 servos
# 1.5" x 2.25" x 0.5" thick (40 x 65mm x 13mm)
# Programmable for Pistol-grip or Stick transmitters
# Programmable Low-Voltage-Cutoff (LVC) to save your LiPo cells
# Programmable PWM to match your motor's inductance best
# Weighs only 1.2oz (41g) including wires
# 4-FET design for low on-resistance (.0008 ohms!!)
# 300A surge current, 60A continuous with water cooling
# Three-color LED shows OFF, PARTIAL, and FULL POWER settings
# All adjustments are done on your transmitter - no pots to fiddle with!
# Universal JR-style servo connector (compatible with Futaba, Multiplex, Hitec, and Airtronics Z
# 12" servo leads allow flexible positioning
# Fail-safe powers down on radio signal loss (but doesn't glitch)
# Safe-On feature prevents glitching on power-up
# 12AWG wire for minimum resistance
# Recommended for 6-cell Stock and Modified motors (N1, N2) and 12-cell Speed 700
# Manual available Online
Old 02-13-2006 | 01:25 PM
Can you post the link to the manual? And who makes it? Does the Water cooling require an optional part, or is simply a matter of plumbing?
Old 02-13-2006 | 05:53 PM
http://www.rc-hydros.com/ its a victory controller. they competely redid it for me, ne wones go for $90, this is as good as new ! it has the watercooling built into it, you just need a water pickup and some tubing (plumbing).
let me know if you want it, if not its going on the for sale section ASAP !
thanks, Dave
Old 02-13-2006 | 08:56 PM
E-Mail me at gordon at niessen dot "to" and we can discuss it. Looks very interesting.
Old 02-14-2006 | 08:07 PM
CHECK YOUR PMS'S i tried your email but i was somewhat lost?
Old 02-14-2006 | 08:13 PM
Sorry, I get too much spam in my diet and am trying to cut back.
gordon a_t niessen.to
Simpler?
Old 02-14-2006 | 08:17 PM
you should have mail?
Old 02-16-2006 | 12:06 AM
hello i just purchased a fast cat and it needs 1 rudder do you know where i could find one.thanks
Old 02-16-2006 | 12:15 AM
Gordon,
Simplest thing to do is to determine how much current your motor draws at max and get an ESC that's rated for that. That usually means doing a 'stall' test on the motor to find max amps. Then just read the ESC specs till you find one that will handle it. A little 'extra' ESC is better than not enough ESC.
- 'Doc
Old 02-16-2006 | 07:56 AM
Don't think they are being sold anymore. You might find an alternative at your local hobby shop. Or one that can be cut down to fit.
