Originally posted by Vince
your engine should quit when the throttle is fully closed. Either you have a small vacuum leak, or you have the low speed needle set too lean.
Vince
I should have said as it is opened further from the idle position. (Which seems fine). Will take a look at resetting the idle mixture a little richer. Thanks.
