Brisson low speed
Anyone have a problem with little or no change in rpm/power as the throttle is opened the first few clicks? Engine performs fine in all other regards. Idles fine and doesn't quit. Any fix?
Originally posted by Vince
your engine should quit when the throttle is fully closed. Either you have a small vacuum leak, or you have the low speed needle set too lean.
Vince
Vince
