RCU Forums - View Single Post - My CG Machine
Old 02-17-2006 | 04:08 AM
TommyWatson
Default My CG Machine
While I was in Hong Kong last week, I found some cheap digital scales (A$12 each).
I decided to try the method used in light aircraft to find the Centre of Gravity.
I put the model on the scales as shown and measured the distance between the main and nose wheels. A simple Excel spreadsheet gives the CG as a distance from the Main wheels or any other point such as the leading edge. Works for a taildragger but the model needs to be level.
It is a simple matter to add or subtract weight from the nose to get the correct cg.
Ok I know it is a bit of overkill, but I found it interesting.
These scales have a max of 5 Kg, so the model weight would be limited to just over 10Kg. Big enought for all my stuff.
Regards
ID:	409798   Click image for larger version
ID:	409799   Click image for larger version
