RE: NEW QUEST
Seth, The front compartment (fuel tank) broke off, the sides broke away from the bulkhead where the wing slot is. The wing bulkhead remained in place. There is not much material for support on the sides. And the top of the fuel tank compartment was not glued, to complete a box structure. I believe you would be ok if you put some small triangle stock in the corners and glued and glassed the top cover on the fuel tank compartment.
