RCU Forums - View Single Post - How do I visually add a prop in G3
Old 02-18-2006 | 05:13 PM
Rat1's Avatar
Rat1
Default How do I visually add a prop in G3
I was doing something with a downloaded shocky 330 and lost the visual prop.
Yes it was Ricks 330 shocky. I changed the fuse design from rootframe to cs_mmvs. When I did that the prop disapeared from view. I tried changing it back but the prop did not come back.
This helped cure the ability to hold a knife edge. I tried adding a second horizontal fuse like a real shock flyer but this would not let me pull the tail over the top. I have no way of changing the dimensions of a horizontal fuse so that it is narrower at the tail then at the nose.
Sure would be nice if Knifeedge would fix this editing problem. They need to also change the adding options so we can add a visual prop if need be.
So if anyone could give me a hand with these two issues (the prop and the horizontal fuse) then please let me know. I can try and send the the plane for them to fix and send it back to me. [email protected]
